4000Nex Stuck in Boot Loop
By JerryHa · Mar 09, 2017in NEX Series💬 14 posts👁️ 11,661 views
Posted Mar 09, 2017 · 17:25 UTC#1
My 4000Nex recently stopped working on me after 2 years of regular use. It would boot to the screen with the Pioneer logo and "Loading..." for about 15 seconds and restart over and over. I have tried:
-Disconnecting the car battery
-Pressing the tiny reset button
I believe the internal SD card is corrupted and will need to be replaced. Where can I find instructions on replacing the SD card and flashing the new SD card with the backup image?
Edited Apr 02, 2017 by JerryHa
Posted Apr 02, 2017 · 07:46 UTC#2
bump
Posted Apr 18, 2017 · 20:20 UTC#3
Hi Jerry,
I am in the same exact boat. Had the unit for 2 years then it started to do the continuous boot screen restarts. I pulled out the internal SD and found that it wasn't recognized by a Windows or Mac system.  Still waiting for a backup img for the 4000nex.
The internal SD card is located below the CD transport on the front right side. See the photo in the link below.
https://www.dropbox.com/s/257feg05qzcc33d/4000nex_SD_Location.png?dl=0
Posted Apr 19, 2017 · 14:50 UTC#4
Hi Guys,
I was able to get my unit fixed after chatting with the helpful folks on the slack channel below. They can provide the img files and any additional help you may need at restoring your unit. Good luck!
https://avicsignup.herokuapp.com/
Edited Apr 19, 2017 by jhyphinwill
Posted Jul 16, 2018 · 08:30 UTC#5
All regards to me tonight, I will write a detailed instruction on how to restore your device from any state.
Posted Nov 17, 2018 · 03:07 UTC#6
Dang. I need this actually. MY head unit has worked fine for 3 years and randomly started doing the dreaded boot loop. I am reading through the forums thoroughly before attempting to modify or change the firmware. looks like the general consensus is that the internal sd card is bad.
Can anyone help a brother out with a walk through? TY
Edited Nov 17, 2018 by jthatcher
Posted Aug 02, 2019 · 02:00 UTC#7
Did you ever get any help with this??? I’m finding myself in the same boat.
Posted Jul 13, 2020 · 17:01 UTC#8
Same problem but cant get to the SD as the screen won't flip up so I can remove it as it won't fully boot up. I had 1 day that it suddenly worked fine but after turning the truck off again it went right back into boot loop.
Posted Aug 30, 2020 · 15:42 UTC#9
same problem here. Stuck in a loop. Tried disconnecting the battery and resetting. My customer splash screen image is still there so I'm not even sure if I actually reset it . No help. Can open face to get to the SD card because It won't open. How can I get it to reset?
Posted Sep 12, 2020 · 20:07 UTC#10
I have a 4500NEX a little passed the 1 year warranty. Was working fine and like others have said, shut vehicle off went into a store, come back out and all of a sudden getting the boot loop everytime. I can’t access the SD card because it never fully boots. I’m hoping somebody has some knowledge to drop or link ;)
Posted Jan 22, 2021 · 20:10 UTC#11
Did you fix it? Can we get some more info about the install? Is there an interface or is it a basic harness install? Were crimp connectors used or was it soldered?
Posted Feb 07, 2021 · 00:02 UTC#12
Any way to get the faceplate off? My unit is doing the boot up looping problem.
Posted Sep 03, 2021 · 23:58 UTC#13
This forum seems pretty useless as far as I can tell.    It has lots of people  with the same Pioneer radio problem... but no solutions.
Posted Sep 04, 2021 · 05:15 UTC#14
Does anyone know whether the image file for the 4400 will also work to solve the same boot loop problem on my 4200NEX ?
