Condi Hack Mode SUCESS on X950 (updated from x930)
By stephyd · Mar 18, 2017in Hacks/Mods💬 5 posts👁️ 3,094 views
Posted Mar 18, 2017 · 12:08 UTC#1
WARNING: FOR DEV PURPOSES ONLY. DO NOT INSTALL IF YOU DONT KNOW WHAT YOU ARE DOING! YOU CAN DAMAGE AND BRICK YOUR DEVICE!
AND DO NOT COME POST "I BROKE MY DEVICE HELP ME!!!" IF YOU DIDENT NOT FOLLOW PREVIOUS WARNING!!!!
So i was able to run condi hack on a x950 upgraded from a x930, running firmware 6.0 (from the forum with 2015 map update....)
After fiddling with my unit a bit, i discovered that the /SDMMC reference was outdated. So after some modification to condi's .msrc scripts.... I updated all references to /SD from  /SDMMC. I also changed all reference to PRG1 from PRG0 to suit my needs.
Result: Condi hack working on 6.0
I will not post files right to prevent end users from trying it out and I will post pictures later
Have fun :)
Posted Mar 18, 2017 · 12:55 UTC#2
I want to point out that what you have is NOT an X950-BH.  That is different hardware. A real X950-BH doesn't even run v6.0 firmware. You have a X930 running v6.0.  I hope you don't confuse real X950-BH owners into trying to install Hackmode.
Posted Mar 18, 2017 · 12:59 UTC#3
I belive i made myself clear with my warning, butI can edit if you would like...
Posted Mar 18, 2017 · 13:20 UTC#4
BTW condi hack mode hasent been working since 920bt if im not mistaking
Posted Sep 03, 2017 · 17:54 UTC#5
Just the opposite. You made it sound like you found a way to update a x930 to run X950 firmware and install HackMode on a x950. I know what you are trying to say but your claims would confuse many people.
Edited Sep 03, 2017 by RonS
