Hey everyone, Thanks in advance for any help you can offer. ![]()
I'm building up a stockpile of all the parts I need to install my D3 into my 2006 Audi A4.
Background info:
-I'm coming from a Symphony II without bose.
-I have the Metra 70-1787 harness.
-Also have the PAC_SWI_PS setup as well.
-Ipod cable is on its way
-As is the "Pioneer ADTVA133 Double Din Installation Kit"
-I have a ballin a$$ face/trim plate in the works too.
Problems/Questions:
-I did a little test fit the other day and found that my factory AM/FM antenna cable won't connect to the back of the D3.... Do I need an adapter? Which one?
-There is another cable connected to the back of the SymphonyII and it resembles the GPS port on the back of the D3. Is this the factory GPS cable? Can I use it? Or would it be better to just leave it unhooked and use the antenna that came with the D3?
-With the harnesses, Do I just match the colors of the wires of the D3's harness's to those of the Metra harness? (e.g. Yellow to Yellow, Blk to Blk etc)
-Also whats the best way to join those wires together?
Please hook me up with any info you can. I would like to do a writeup on this later on. I will probably have more questions later.
TIA again,
Dylan
