Speed pulse pop up message
By markich07 · Apr 11, 2017in Problems/Troubleshooting💬 7 posts👁️ 1,332 views
Posted Apr 11, 2017 · 10:16 UTC#1
Hi to all..i have device avic f50bt..device work perfectly but how to remove message speed pulse disconected when i use navigation..i dont wont spend 60+euro for can bus interface..to connect speed input wire..thanks for help in advice and sorry for my bad english..
Marko
Edited Apr 11, 2017 by markich07
Posted Apr 12, 2017 · 14:28 UTC#2
Any one?
Posted Apr 12, 2017 · 20:52 UTC#3
What car do you have?? some cars still have a analoge speedsense. Let me know
Posted Apr 13, 2017 · 07:26 UTC#4
Peugeot 307 hdi 136..2004 year..
Posted Apr 13, 2017 · 12:51 UTC#5
Behind the headlight on the left side there is a bunch of wires, look at a wire with number 6739 on it, that's the wire from the speedsignal
Posted Apr 13, 2017 · 17:41 UTC#6
I will try tomorow..and let u know if i successed..thanks
Posted Apr 13, 2017 · 18:17 UTC#7
markich07 there's a pink wire at the back of your navigation and that's the speedpuls wire, do you have a led measure instrument? if you put the clamb to the ground en the led to the 6739 wire then you can see flikkering the led when you drive with your car. 10km/h should be enough to measure
