I have a Sprint LG phone that seems to just disconnect itself for no reason. I am in the car right next to the unit. I noticed when I tried to get the AVIC Z2 to read the phone book in the phone so it would transfer the information to the unit. Has anyone else experienced this?
Phone disconnects from Bluetooth on its own
The phone works in every other way except when I try to download the phone book. Do not understand why this is.
Most LGs have issues, whether it be sprint or verizon
I wonder has anyone discovered the fix to ensure the phone works the way it should
send it for service have them update the SW
The z2 "SHOULD" disconnect from the phone,when you transfer your phones address book to the z2.i dont know your phone.i have a razor v3 and could only transfer 1 contact at a time and from what ive read most phones can only do 1 at a time also.so the way mine worked was to select the contact from the address book then there is a screen that lets me edit and other options,you need to find 1 that says "SEND" press SEND and it will connect to the z2 and send that contact.after it has been sent the z2 will ask if you want to do anther.answer yes/no and repeat with the next contact.
I know my Treo 650 disconnects all the time and I get that message bar when it does. But, it usually reconnects a minute or two later.
