HELP: Incompatible USB - 8200
By Amarillo6oh · May 25, 2017in NEX Series💬 7 posts👁️ 2,266 views
Posted May 25, 2017 · 20:51 UTC#1
The Pioneer CD-IU52 usb cable is plugged directly into the back of the HU into USB 1
I read to try another USB cable but I eliminated that problem by going directly into the head unit. Has anyone had an issue with the Pioneer cable?
I have done a reset  on the unit as well as rebooting the phone.
I have also tried 3 different Apple HDMI/ lightning plugs
iPhone 7 - iOS 10.3.2
Edited May 25, 2017 by Amarillo6oh
Posted May 26, 2017 · 02:22 UTC#2
Did you make sure you went into smartphone setup in the head unit and set it to Apple??
Have you tried the phone as an iPOD using the head unit's normal ipod playback, not in carplay?
I'm using the amazon basics lightning cable going through a USB bulkhead connector mounted in my center console(https://www.amazon.com/gp/product/B00XL09YLW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1).  Works great with my iphone 6 iOS 10.3.1
Posted May 26, 2017 · 14:41 UTC#3
Yes
No
It just won't recognize the Pioneer USB cable - I have the cable you show but it's useless if it won't even recognize the Pioneer cable.
Posted May 26, 2017 · 19:03 UTC#4
Wait so you're saying it works fine going directly to the head unit and not using the pioneer cable?   You're only complaining about the pioneer cable?
Posted May 26, 2017 · 19:46 UTC#5
NO. It doesn't work at all, plugged directly into the HU
I ordered a replacement.
Posted May 28, 2017 · 21:43 UTC#6
I also have same problem when you plug in iPhone does your unit freeze
Posted May 30, 2017 · 01:01 UTC#7
Mine doesn't even see the iPhone
