Okay, I took the unit apart today.
Actually much easier than I was expecting it to be ... please note the following:
* There are only two sizes of screw heads, Philips #1 and #0. Use GOOD screwdrivers! Many of the screws, especially the smaller ones, are in very tight, I almost stripped one, so a cheap philips screwdriver may not cut it here.
* To release the display from those first two screws at the bottom you have to separate the metal holding tabs a bit to get them off the posts that the screw goes into. this is a tiny post that allows the screen to swivel against the holding tabs during the opening/closing action
* The unit is made of surprisingly few modules, and they are all connected by ribbon cables. Take your time with the ribbon cables, there are three types of connectors that I ran across:
- flip lock bar, flips up to release cable from holder
- pull out bar, pull it out towards the ribbon about 1/8" to release the cable from holder
- pull out, the ribbons with a hard blue plastic tab at the end of the cable ... these you just pull out
* I've attached a photo of all of the screws I removed to get to the AV PCB assembly. Not a great many screws. Fyi I made a makeshift adhesive screw holder by alternating masking tape strips face up/down on the paper ... works great.
I could not see anything visually wrong with the AV PCB ... the antenna jack seems to be attached with large solid solder joints, no burn spots anywhere that I could see, nobulging capacitors. I am posting a bunch of photos of the board, if anyone has a suggestion on what to inspect more closely let me know and I will look and/or post more photos.
Also, while I have the unit disassembled, if you have interest in what any of the other components look like let me know and I will be happy to take and post more pics.
Thanks. John
