4200 SD card problems & MP3 artwork issues - Help?
By EdD2112 · Jun 08, 2017in NEX Series💬 5 posts👁️ 2,046 views
Posted Jun 08, 2017 · 05:06 UTC#1
Hello! New user here, hope someone can help me figure out what I am doing wrong. 2 issues I am having with my new 4200NEX with the SD card.
1- I can not figure out how to get my MP3 files to show the album artwork when playing. BUT, strangely enough, the artwork shows up fine when the same MP3s on the same SD card are played through MIXTRAX. I thought a upgrade to the firmware might fix the problem, but no luck there.
2- Out of a handful of SD cards, I can only get one to work in my system. Does anyone know if there is something I need to be doing to get them to work? Or what brand/format of SD card will work?
Posted Jun 10, 2017 · 16:58 UTC#2
The only thing I can suggest is that I know the artwork can't be larger than 600x600, but I'm guessing that's not the problem if it shows in Mixtrax.
Posted Jun 10, 2017 · 19:13 UTC#3
Probably depends on how you format your SD card.
Posted Jun 11, 2017 · 21:15 UTC#4
I assume your using .jpg for artwork.
Posted Jun 12, 2017 · 04:25 UTC#5
also check the size of the images. i usually use 300x300 on my nex8000. images above 500x seems to not work so well
Edited Jun 12, 2017 by SpecTrax
