TestMode
By RonS · Jul 04, 2017in Problems/Troubleshooting💬 3 posts👁️ 7,701 views
Posted Jul 04, 2017 · 12:59 UTC#1
TestMode is much safer and easier to use than Hackmode - which installs and modifies your system. Sometimes the install goes awry, leaving your unit unable to boot.
To get into TestMode on most X and Z series units, download this file supertestmode.zip to a PC, unzip it, put TestMode.key on a FAT32 formatted SD, and insert it in your unit.
IFAIK this file doesn't work on  x950 & z150, but if it does, or someone knows one that works - please post to this thread.
Edited Jul 04, 2017 by RonS
Posted Jun 25, 2018 · 02:06 UTC#2
Hi there,
I recently bought a used car and I had to replace the battery when I was prompted with this password issue.
My head unit model is AVH-X8750BT, how do I gain access to the SD card slot as it is behind the touch panel?
I do have  2x external USB ports but nothing happened when i inserted the sd card with an adapter.
Image result for AVH-X8750BT
With Regards,
Alex
Posted Jan 19, 2020 · 18:25 UTC#3
You mus be acced from port USB1, behind the unit, normaly is the superior USB.
