Hello,
I am new to this forum and have read the rear backup camera issues related to the NEX radios, but did not see one that quite fit my situation. I have my rear camera installed. The ground wire from the camera hooked up to my brake lights, the yellow input goes to the brown input jack, and the red connected wire from the RCA jack to my head unit is connected to the purple reverse brake wire. I have the rear camera input on and when I switch to reverse the backup camera comes on. When I switch out of reverse, I go back to the screen that I was on before (i.e GPS). However, ever 5 seconds, it goes back to camera view, but no video. It doesn't matter whether or not I have this set to battery, engine or ground.
Has anyone had this issue before? It is annoying to have to switch the camera off and then have to turn it back on again when I need it. Does this sound like I may have a bad head unit, or am I doing something wrong? I initially had a 4200 NEX that worked fine. I did add the brake bypass to the 4200 which I know it is not needed for the 8200, but I left that In place. The 4200 NEX worked fine and didn't have this problem. My 8200 did come with the firmware upgrade already installed.
Please help so that I can know whether or not I need to return this to Amazon before my 30-days are up. Thanks!
