Z120BT Time is 10 minutes off
By cbarefoot925 · Jul 25, 2017in Problems/Troubleshooting💬 3 posts👁️ 1,329 views
Posted Jul 25, 2017 · 14:56 UTC#1
I've had the Z120BT installed in my truck for 4 years, and a month ago I had my dashboard replaced due to cracks.  When I got the truck back, the time was behind by 10 minutes.  I can't seem to find any way to adjust the time, and not just the time-zones.  I tried disconnecting the battery to see if that would do the trick but nothing.  Has anyone seen this?
Posted Jul 25, 2017 · 15:18 UTC#2
Since we can only set the time offset in hours  and whether we use DST, I think it gets its time from the GPS satellite signal. Does your GPS still work - or maybe you haven't been in line-of-sight of any satellites long enough to get a "fix"?  Just wondering if the GPS antenna got disconnected when the dash was removed.
Edited Jul 25, 2017 by RonS
Posted Jul 25, 2017 · 15:25 UTC#3
I think that must be it.  I don't use the GPS anymore but I realized when passing over it that the location wasn't updating.  I'll have them check that.
