x920 Settings button grayed out
By IADutch · Sep 06, 2017in Problems/Troubleshooting💬 5 posts👁️ 1,481 views
Posted Sep 06, 2017 · 19:07 UTC#1
I added a backup camera recently. Multimeter shows connection to backup light has power. Plugged into Rearview camera in on the head unit.
Problem: won't show the rear view when car is in reverse. After much searching, I found a box in the online manual that says to go into the settings and turn camera view on.
When I try that, the settings button is gray. Only the AV and Audio buttons are colored.
What do I do to get the settings button active?
Thanks.
Posted Sep 06, 2017 · 19:21 UTC#2
Thanks.
Parking brake.
Posted Sep 07, 2017 · 01:22 UTC#3
Explain a little more please.
Posted Sep 07, 2017 · 01:39 UTC#4
Parking brake must be set to access some of the settings. If it is set and it is still grayed-out then your unit is not properly installed (parking brake wire is not connected or not bypassed).
Edited Sep 07, 2017 by RonS
Posted Sep 07, 2017 · 21:27 UTC#5
That worked, thanks.
