weird stuff with the arrow on map d3
By jpspeed3 · Sep 22, 2007in Hacks/Mods💬 21 posts👁️ 3,093 views
Posted Sep 22, 2007 · 02:09 UTC#1
ok here is my problem. I will be driving down the road and on my map I am going down the correct road but my arrow is pointed in the wrong direction. like if I am going west my arrow will point north,south, any diretion but the way I am actually traveling. I have re set the unit twice and still no luck. my vss wire is also not hooked up. I called pioneer and they said my gyro is bad and I have to return my unit does this sound right to you guys please let me know what you think I need some help.
Posted Sep 22, 2007 · 02:11 UTC#2
Why don't you hook up your VSS wire and reverse wire before you send it in for repair? Pretty easy test
Posted Sep 22, 2007 · 02:13 UTC#3
how do I do that and what does the reverse wire have anything to do with it
Posted Sep 22, 2007 · 02:29 UTC#4
make sure your set for "heads up" and not "north up"
Posted Sep 22, 2007 · 02:32 UTC#5
is that the small 2 sided red\white arrow on the map screen if so I have tried that multiple times
Posted Sep 22, 2007 · 02:35 UTC#6
yep, thats it
Posted Sep 22, 2007 · 02:49 UTC#7
yeah I do try it and it does change the direction but the arrow is still sideways or not on the actual road itself it is right by it but turned a little, there is also no estimated time of arrival
Posted Sep 22, 2007 · 03:24 UTC#8
You got the mazda right? You try hooking up the vss wire that we talked of in the other post?
Did you connect the reverse wire? This wire helps the unit know what your vehicle is doing.
Posted Sep 22, 2007 · 03:31 UTC#9
yeah I have the mazda I actually have the car in my garage I am trying to hook the vss wire to the instrument panel and I have everything apart and I still can't seem to get the pulse, where does the reverse wire go to?, when I go to 3d calibration will you hear the pulse once u are moving or when the car is running?
Posted Sep 22, 2007 · 04:09 UTC#10
When it is moving. You will see the speed sensor signal number start climbing.
What I did was look at the reverse light wire that plugs in for the light. I "think" mine was green/orange(?). I then went to the passenger kick panel and removed it and looked at the harness that has the wires coming into it that came from the rear of the vehicle. Once I saw the same color wire, I put a volt meter at that connect at the harness and put the car in reverse (with parking brake on) and if It read a voltage with it in reverse I knew I had the right one. Also be sure to check that there is not volts when it is in park. I then tapped into that wire.
Posted Sep 22, 2007 · 04:34 UTC#11
I just took the unit out of my dash it is still connected and it was on map and I moved it in my hands and the arrow rotated so I don't know what the hell is going on
Posted Sep 22, 2007 · 04:52 UTC#12
Things that make you go hmmmm. I dunno, but I would at least try to find that reverse wire and if that doesn't set it straight, then maybe the gyro is toast. You'll need that wire, even if you have to return your unit for a new one.
Posted Sep 22, 2007 · 23:04 UTC#13
hey trol thanks for the info on the vss wire I hooked it up and it finally worked and the thing about the arrow is I just needed to modify my current position in the map menu. everything works great I tested it out on my way home. thanks for all your help
Posted Sep 22, 2007 · 23:07 UTC#14
You think you could turn off the bold and italics please? It's quite unnecessary.
Posted Sep 22, 2007 · 23:13 UTC#15
sorry i didn't think it was that big of a deal whah
Posted Sep 23, 2007 · 01:42 UTC#16
How can u tell if ur reverse wire is hooked up or not and i thought it was for the back up camera?
Posted Sep 23, 2007 · 02:58 UTC#17
Thats great to hear!!! Now don't have to much fun while using it. :)
Posted Sep 23, 2007 · 16:38 UTC#18
if your back up wire is hooked up it will help tell your navi your car is going in reverse it also turns the camera on too. you can tell it is hooked up b going to navi menu, system options, connection status and you will see something that says back signal, that is your reverse wre
Posted Sep 23, 2007 · 17:21 UTC#19
my back signle alswyas says low even when its in reverse, what will it say when i get it hooked up and put the car in reverse?
Posted Sep 23, 2007 · 17:33 UTC#20
I'm not sure mine is still not hooked up, but I think it would say good
Posted Sep 23, 2007 · 17:35 UTC#21
Back signal Low is normal
