avic-8200nex reverse camera installation question
By leeryan895 · Oct 10, 2017in NEX Series💬 4 posts👁️ 1,732 views
Posted Oct 10, 2017 · 05:23 UTC#1
I am trying to connect a reverse camera to Pioneer avic-8200nex.
The RCA cable running from back to front has a short red pigtail on each side.
My question is: for the short red pigtail of RCA cable on the head unit side, which line I should connect to? Red, purple/white, or any other lines?
thanks!
Posted Oct 13, 2017 · 04:22 UTC#2
answer for myself:)
I did not use the red pigtail on either side.
Rear camera works just fine, ~3 secs delay after switch to reverse.
Not sure whether the trigger wire connection will speed up a little, tired to go back to pull all out and in
Posted Oct 13, 2017 · 04:32 UTC#3
that is normal
Posted Oct 13, 2017 · 05:24 UTC#4
that is normal
most factory backup camera video shows up immediately after switch to reverse though
