Replacing Factory Nav with Aftermarket AVIC
By stream70 · Oct 28, 2017in NEX Series💬 6 posts👁️ 1,616 views
Posted Oct 28, 2017 · 15:09 UTC#1
If one has a 2013 Nissan Altima 2.5SV sedan with a factory installed 7 inch NAV with 6 speakers, will the Pioneer AVIC series 8100/8200/8201 replace it successfully?
My current Altima NAV does not show car info, just GPS,  Bluetooth, am/fm ,backup camera, ipod.
Heard that Pioneer Aftermarket units cannot replace Nissan Factory OEM NAV, only a non NAV radio can be replaced,  Is that true? I hear conflicting information.
Thanks !
Edited Oct 28, 2017 by stream70
Posted Oct 28, 2017 · 17:00 UTC#2
Pioneer Nav units work just fine replacing a bunch of factory OEM nav units. You need t he correct interface and wiring harness. Check Crutchfield to see what will work for your Altima
Posted Oct 29, 2017 · 00:18 UTC#3
Crutchfield says NO to the Pioneer AVIC 8100NEX to replace my 2013 Altima 2013 Factory OEM NAV.
Has ANYBODY here ever replaced a 2013 Altima's Factory NAV unit with an aftermarket?
Edited Oct 29, 2017 by stream70
Posted Nov 02, 2017 · 19:14 UTC#4
check dimensions of your new head unit which you intend to install with the existing one, you may have to buy a facia plate, there are plenty on aliexpress,...then check the harness, you might get adapters for it or you may need to cut the wires, you car electrician will know better
Posted Nov 03, 2017 · 00:45 UTC#5
Im not sure what your asking....you want to know if the Pioneer unit can "physically" replace the factory unit? Of course it can if the space is big enuff...you tell us..Ive never even been in an Altima.
Posted Nov 10, 2017 · 16:41 UTC#6
I would check with the nissan forum as they would know the car better than any of us.  If there is a harness available, and the dimensions of the radio fit, I don't see why you couldn't.
