With my second hand car, i got also an Pioneer F40 installed. The seller allready mentioned, that there are some issues with this device. As an it guy, i was optimistic to fix those issue(s) by myself.
After some researching, i found the pioneer service manual, different firmwares, the supertestmode-tool and maps. Following to service manual, i tried to re-install all software, but i'm failing at "3. PROGRAM FORCED WRITE"
My unit does fail at the first step:
If i perform all other steps, like the platform write - everything is rocking fine, but the unit is still not working as expected.
Any hints how to proceed and restore my device? The NAND read/write test is running without anny issues.
Currently, it does play music from all sources, but is unable to remember my personal language settings, and to navigate (but it is able to show the current map/position without any issue)
Kind regards, Mike
