GM XM Antenna
By Lophat · Sep 22, 2007in XM/Sirius/HD Radio and Traffic Receivers💬 8 posts👁️ 2,800 views
Posted Sep 22, 2007 · 17:25 UTC#1
Hello all,
I am puting a new Avic-Z2 with a GEX-P10XMT in my new 2008 Impala SS optioned with XM and Bose. I have found all modules etc to keep all OEM functionality, such as OnStar and wheel controls and safety/door chimes. But, I have not found any way to use the existing XM antenna. Does anyone know if it is possible to use the existing XM antenna or possibly re-end/hack it to work with the GEX-P10XMT? Any and all info would be greatly appreciated! Thanks! :)
-Steve
Posted Sep 22, 2007 · 18:01 UTC#2
u mean the yellow antenna plug? ive never had trouble pluggin them into any xm box. worst case you have to take all of the plastic off of the factory side (the yellow) and it will plug in good luck
Posted Sep 22, 2007 · 18:57 UTC#3
I do not know if the plug is yellow, I have not started getting into anything yet. I know the antenna plug on the pioneer XP piece is a square with a round type deal in the middle. I can not find a picture or any documentation of a GM XM antenna or antenna plug.
Posted Sep 26, 2007 · 20:10 UTC#4
Most GM's are 2 wire set ups, one wire for Satelite, the other for the repeaters.
If it is a 2 wire antenna, it will work just fine except for the repeaters (tunnels, downtown areas).
Posted Oct 30, 2007 · 20:51 UTC#5
Yes the factory antenna will work. All you have to do is take off the plastic around the main connector and it will plug right into the aftermarket xm unit. Theres just a little clip on the side you pop that off and then the plastic connector comes right off. Then you are left with just a bare smb connector which will work perfect.
Posted Oct 30, 2007 · 22:20 UTC#6
Remove the factory yellow connector, and file it from the inside so it can "lock" into the pioneer tuner. If you don't you may have a prblem keeping the antenna cable in the plug. :shock:
Posted Oct 30, 2007 · 23:06 UTC#7
You can also shave off the alignment tab on the Pioneer XM tuner's ant input(pink plug, tab is in the shape of a triangle). This will allow you to keep the factory ant plug intact and it fits more secure.
Posted Oct 31, 2007 · 03:10 UTC#8
What I did was take off the yellow plastic connector and then i found an antenna extension cable. It fit snug to both the pioneer xm unit and the factory plug. This way I didnt change anything factory so if i do sell my car one day i can take it back to exactly stock.
