I have an Pioneer AVH 4200NEX that I have configured as follows:
Front Pre Out into my Power amp Front Inputs
Sub Pre Out into my Power amp Sub Inputs
Rear speaker level out from NEX connected directly to my rear speakers.
I have the NEX set to ON for Rear Speakers ON/OFF selection.
My rear speakers are barely audible in this setup. Is there some other setting on the NEX that needs to be set in order for these rear speakers to play at a reasonable volume? I understand that the Pre Outs to a power amp for the fronts is obviously going to produce more volume, but I expected to have a reasonable amount of volume from the rears. Even if I "Fade" the balance all the way to the rears, they are still barely audible and if I crank up the rears with the balance all the way to the rears, I get a bit more volume but it starts to distort more than I would expect. Any help is appreciated.
Thanks in advance.
