Bluetooth Connect/Disconnect
By Agro · Sep 23, 2007in Problems/Troubleshooting💬 7 posts👁️ 1,317 views
Posted Sep 23, 2007 · 19:52 UTC#1
Lately I have noticed that my Blackberry Pearl 8100 keeps connecting and then disconnecting over and over to my Z2. The phone is in my lap or in my pocket and the BT module is mounted under the steering wheel under the plastic plate, so literally maybe 18" max away. Whats the deal?
Posted Sep 28, 2007 · 16:31 UTC#2
We had the same problem with our first phone... worked perfectly for 2 months... then reset the entire AVIC and worked fine for about 3-4 weeks then again the connection/disconnecting. We tried a 2nd phone that is listed as compatible did almost the exact same thing there...
Then we purchased the BB Pearl 8100... worked fine no hitches for about 4 weeks, then the same crap. Finally sent the unit in to Pioneer for repair... firmware update was done and it did NOTHING.
Good Luck as I suspect there is something more happening here that Pioneer is not even aware about.
Even when I try to delete the device on the phone, and rematch it to the AVIC, there are times where the phone displays that there was no device found.
Posted Sep 28, 2007 · 18:48 UTC#3
I think I will COMPLETELY reset the Z2 to factory. 100%
AND I think I will flow away my Blackberry and re-load the latest handheld software.
We'll see.
Posted Sep 28, 2007 · 19:03 UTC#4
we did the factory full reset as well. The phones would work fine for a while... then the same thing... bam!
Where do you get the software update for the 8100 Pearl?
Posted Oct 04, 2007 · 05:06 UTC#5
Problem solved after re-loading the Blackberry handheld software on my Perl 8100. I didn't keep the settings, complete purge. But yeah perfect now.
Posted Oct 09, 2007 · 16:21 UTC#6
This has just started happening to me. How do you reload the Blackberry handset software? Is this a download from the Blackberry website?
Posted Oct 09, 2007 · 16:22 UTC#7
Your provider
i.e. my.t-mobile.com has it for my 8100
contact them for more info
