5200 NEX Install questions
By LilRedExp · Feb 11, 2018in NEX Series💬 3 posts👁️ 1,465 views
Posted Feb 11, 2018 · 17:39 UTC#1
Hi All!
New to avic411.com and looking hopefully for the answers to my questions. I am currently finishing the re-install of my 5200 NEX in my 05 RAM 1500. When it was initially installed the speed signal input and reverse gear signal inputs were never connected. Can anyone tell me where to connect these wires on my RAM? Is the reverse gear input just looking for a voltage signal (i.e. reverse lights)? That one I can probably figure out but the Speed signal has me stumped. Can anyone out there help me?
Posted Feb 12, 2018 · 13:07 UTC#2
2005 Dodge/Ram RAM - North America DirectWire Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts red (40A) + ignition switch, black 14 pin plug, pin 11
Second 12 Volts red (40A) (except SRT-10) + ignition switch, black 14 pin plug, pin 1
Ground (chassis ground)
Starter yellow (except SRT-10); yellow/orange (SRT-10) + ignition switch, black 14 pin plug, pin 13; starter button, white 6 pin plug, pin 3 (SRT-10)
Ignition pink/lt. green + ignition switch, black 14 pin plug, pin 3
Second Ignition pink/white + ignition switch, black 14 pin plug, pin 2
Third Ignition pink/yellow (12 AWG) (SRT-10) + ignition switch, black 14 pin plug, pin 9
Accessory dk. blue (except SRT-10); pink/dk. blue (SRT-10) + ignition switch, black 14 pin plug, pin 8
Second Accessory pink/yellow (14 AWG) (except SRT-10) + ignition switch, black 14 pin plug, pin 9
Third Accessory pink/yellow (16 AWG); pink/yellow (12 AWG) (except SRT-10) + ignition switch, black 14 pin plug, pins 14, 10
Keysense violet/tan - ignition switch, black 14 pin plug, pin 5
J1850 white/violet (PCI BUS) data data link connector, black 16 pin plug, pin 2
IMMO Data white/violet (PCI BUS) data Sentry Key Immobilizer Module, black 6 pin plug, pin 2
Power Lock violet/dk. green - 820 ohms driver kick, door harness
  Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Power Unlock same as power lock wire - 330 ohms
Lock Motor lt. green 5 wire driver kick, door harness
Driver Unlock Motor tan/lt. green 5 wire driver kick, door harness
Passenger Unlock Motor violet/lt. blue 5 wire passenger kick, door harness
Factory Alarm Arm violet/lt. blue - 644 ohms driver kick, door harness
  This will also do door locks. Arm/lock is negative trigger thru a 644 ohm resistor. Disarm/unlock is negative trigger thru a 1565 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire -1565 ohms
Disarm No Unlock see factory alarm disarm
Parking Lights (+) white/yellow (L), white/gray (R) + harness at top of driver fender
Parking Lights (-) white/lt. green (see Tech Doc 1082) - 270 or - 590 ohms headlight switch, black 8 pin plug, pin 8
Hazards white/orange - hazard switch
  Hazards are negative trigger thru a 120 ohm resistor. MUST use a relay.
Turn Signal (Left) use hazards wire
Turn Signal (Right) use hazards wire
Headlight white/lt. green (need to relay isolate from switch - 470 ohms headlight switch, black 8 pin plug, pin 8
Reverse Light white/lt. green + inside mirror or plug by PCM
  The PCM is on the passenger side firewall.
Left Front Door Trigger violet - driver kick panel
  Use all four wires and diode isolate each. See Tech Doc 1076 for wiring information.
Right Front Door Trigger violet/white - passenger kick panel
Left Rear Door Trigger violet/orange - driver kick panel
Right Rear Door Trigger violet/yellow - passenger kick panel
Dome Light yellow/lt. blue or yellow/orange + driver A pillar or cluster
Tachometer dk. blue/gray ac PCM, orange plug, pin 34
  The PCM is on the passenger side firewall. On SRT-10 models, the tach wire is in the black plug, pin 18. On diesel models, the tach wire is at the ECM on the lower driver side of the engine, 60 pin plug, pin 24, or at the camshaft position sensor just left of the ECM, in a 3 pin plug. On gas models, can also go to any ignition coil or fuel injector and use the wire that is NOT brown/white.
Wait to Start (see Tech Doc 1091)
  On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Speed Sense dk. green/yellow   PCM, top black plug, pin 13
  The PCM is on the passenger side firewall. On SRT-10 models, the vss wire is in the white plug, pin 27. On diesel models, the vss wire is at the ECM on the lower driver side of the engine, 50 pin plug, pin 11.
Brake Wire white/tan + brake pedal switch
Parking Brake dk. green/white - parking brake switch
Horn Trigger dk. green/violet - horn switch
Wipers brown/white (L), brown/orange (H) + windshield wiper motor
Left Front Window (Up/Down) orange/lt. green - orange/white A driver window switch in door
Right Front Window (Up/Down) orange/tan - orange/gray A driver kick, door harness
Left Rear Window (Up/Down) orange/white - orange/gray A driver kick, door harness
Right Rear Window (Up/Down) orange/lt. blue - orange/dk. blue A driver kick, door harness
Sun Roof (Open/Close) motor part of module
Radio 12V gray/red + radio
Radio Ground black and black/lt. green - radio
Radio Ignition pink/yellow + radio
Radio Illumination orange/tan (dimmer) + radio
Factory Amp Turn-on (PCI Bus)
Left Front Speaker (+/-) dk. green/yellow - dk. green/lt. blue +,- radio or amplifier behind glove box, 14 pin plug
  The tweeter wires are gray/orange - gray/yellow at the amplifier, 20 pin plug.
Right Front Speaker (+/-) gray/yellow - gray/lt. blue +,- radio or amplifier behind glove box, 14 pin plug
  The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, 20 pin plug.
Left Rear Speaker (+/-) gray/lt. green - gray/dk. green +,- radio or amplifier behind glove box, 14 pin plug
Right Rear Speaker (+/-) dk. green/lt. green - dk. green/gray +,- radio or amplifier behind glove box, 14 pin plug
Center Channel (+/-) gray/brown - gray/orange +,- amplifier behind glove box, 20 pin plug
Subwoofer (+/-) gry/brn - dk. grn/brn(1); gry/wht - dk. grn/wht(2) +,- subwoofer under driver side rear seat
Item Size Depth Location
Headunit DIN and a half   center of dash
Left Front Speaker 6 x 9 5.25 left front door
Left Front Tweeter 4   left front dash
Right Front Speaker 6 x 9 5.25 right front door
Right Front Tweeter 4   right front dash
Left Rear Speaker 5.25 3.5 left rear door
Right Rear Speaker 5.25 3.5 right rear door
Center Channel 2.5   top center of dash
Subwoofer 10   under driver side rear seat
Posted Feb 16, 2018 · 17:18 UTC#3
Forget all that, did you try the bypass method??
