Anybody know if I can use my OEM GPS antenna. Have factory Nav in 2008 C6 Corvette. Going to change from OEM Factory Nav to AVIC7201NEX or will I need to use the antenna that’s supplied with the unit. Thanks in advance. Jeff
C6 OEM Antenna
Update. OE does not fit after market. I used the supplied GPS antenna.
On 8/29/2018 at 10:33 PM, Jeffs64 said:Update. OE does not fit after market. I used the supplied GPS antenna. This is custom GT5- cable that goes to AVIC-F The GT5 is gray from Factory Nav 2008 C6 corvette to green AVIC -F Pioneer GPS PLUG AND PLAY to use OEM GPS antenna with pioneer AVIC RADIO / NAV
Just to let you know with factory GPS antenna the MAP screen in less than three (3) seconds. It would take up to 20-30 seconds with aftermarket antenna supplied with the head unit. And yes they were both located in the same place just a little left of dead center of the inside top of the dash.
Wow, you lucked out finding that adapter. I had a similar issue with the XMRadio antenna in my Porsche, it would not fit the XMRadio tuner. Rather than cut/trim the Porsche OEM connector, I took out my Dremel and cut the outer housing of the XMTuner which was only $39. Worked like a charm. The satellite radio antenna was mounted on the rear trunk lid.
