Calibration will start, but may be inaccurate without speed pulse.
By kbrkr · Sep 19, 2018in NEX Series💬 9 posts👁️ 5,601 views
Posted Sep 19, 2018 · 11:57 UTC#1
Obviously, I did not install the speed pulse wire during my installation as I had a hard time finding the correct wire in my Porsche.
I'm starting to get this error; "Calibration will start, but may be inaccurate without speed pulse."  Whenever I use the Navigation.  When the error is present, the NAV screen is unresponsive.  It has to timeout on it's own.
Anyone have a workaround?
Posted Sep 21, 2018 · 11:36 UTC#2
This message is becoming a problem as it remains on the screen blocking the actual MAP for the entire journey and I can't find a way to clear the message.
Any Ideas?
Posted Sep 21, 2018 · 22:37 UTC#3
Lots of info when I search speed pulse.
Posted Sep 21, 2018 · 23:48 UTC#4
Any Ideas?
Maybe if you stated the model and yr someone could tell how to connect VSS to a pulse wire. Hint - it is in your ABS harness below the brake fluid reservoir. Probably White/Brown for Porsche.
Posted Sep 23, 2018 · 19:22 UTC#5
Yes, thanks.  It's a 2013 Boxster.  According to my wiring diagram,  White/brown is Terminal 31.  There are 4 wheel sensors coming from the wheels into the PCS control unit, but I can't find them.
Posted Sep 24, 2018 · 00:05 UTC#6
I have a 987.2. so your 981 wiring may be different.  Is that a 981 wiring diagram?  I have printed instructions from the EuroMotorSpeed kit. It says to remove the cover over the brake fluid reservoir and you'll find a black 46 pin connector with all the wires for ABS. On mine, it was the BRN/WHT wire going to pin 19. Your's looks different. Basically, any wire that pulses when any wheel rotates will work.
Edited Sep 24, 2018 by RonS
Posted Sep 24, 2018 · 02:44 UTC#7
Thanks Ron, yes this diagram came from my 981 2012-2015 Service Manual.
Thanks for the tip on the Brake fluid cover, I don't think 987 is that different from the 981, it should be in the same location.
Many thanks for your help.
Al
Posted Sep 24, 2018 · 12:08 UTC#8
Al
Pin 38 in your wiring diagram looks promising. I checked my 987 diagram and it looks comparable to my pin 19 (both BRN/WHT and go to a module on the right side of the frunk).
To access you'll have to remove some of the liner plastic trim. Probable just held by a few screws.
Posted Oct 04, 2018 · 23:43 UTC#9
UPDATE:
I received this reply from Pioneer Support which was very helpful.  They responded within 24hrs so I'm quite appreciative.
