AVH-4000NEX stuck in firmware udpate v1.20 loop
By Zamboa4 · Oct 01, 2018in NEX Series💬 6 posts👁️ 3,468 views
Posted Oct 01, 2018 · 18:37 UTC#1
Hi guys,
I have an AVH-4000NEX V1.11 and trying to update to LATEST version V1.20 but the update keeps failing at 66% each time.
I'm using SDHC San Disk card and used the same card  in the past to update from  1.21 to 1.11.
I tried a different approach by using a USB key plugged in port usb 1 but it's not picking it as the FW update source even when SD card is empty.
Any known fix for this. I'm desperate about Pioneer.
Regards,
Edited Oct 03, 2018 by Zamboa4
Posted Oct 02, 2018 · 22:20 UTC#2
Force update with testkey
Posted Oct 03, 2018 · 17:58 UTC#3
Can you please provide more info or a link ?
I tried again yesterday and progress bar reached 100% after that the failed message appeared lol....what a joke Pioneer
Appreciated.
Posted Oct 03, 2018 · 23:37 UTC#4
Ok guys. I hope this can help some of you in the same situation.
 I made the unit out of the coma.
I was actually on v1.11 and i downloaded the exact same firmware.
The unit showed 1.11 > 1.11 which is weird updating to the same version but it worked. The update finished till 100% and the unit booted normally.
Now i'll leave it alone no updates in the future .... thank you Pioneer for the shitty updates.
IMG_9720.HEIC
Posted Jun 10, 2020 · 01:03 UTC#5
I had the exact same problem today. Tried to update firmware on my Avh-4000nex from 1.14 -> 1.20.
the update stopped at exactly 66%. This happened from both USB drive and SD card.
recovered by rebooting with 1.14 files on thumb drive when rebooting.
anyone successfully update this unit to 1.20 firmware?
I also tried updating from 1.14 -> 1.15 and had exact same result. The update crashed at 66% complete.
bummer.
Posted Mar 08, 2023 · 19:45 UTC#6
I updated successfully to version 1.20 after many attempts. Once updated I discovered I couldn’t access Bluetooth anymore. That was 2years ago. I recently found an article stating it was a two part update, the second part being a Bluetooth update. I may try that on a slow day, goodness why so difficult Pioneer?
AVH-4000NEX
