Gps antenna problem detected
By 571529 · Dec 21, 2018in NEX Series💬 6 posts👁️ 2,280 views
Posted Dec 21, 2018 · 12:35 UTC#1
Hey guys, so i have a 6100nex. Recently the navigation shows up “ gps antenna problem detected, please contact dealer or service center” has anyone experienced this? How can i solve it. Maybe hard reset, how can that be done? Thanks in advance
Posted Dec 21, 2018 · 16:53 UTC#2
Where is you antenna located? If it's inside the dash, sometimes it can shift around and if metal interferes you can get that error. Or if the cable got pinched. Hard reset as in putting a paper clip through the reset hole? On yours, it's on the top left, next to the eject button.
Posted Dec 21, 2018 · 17:35 UTC#3
I placed it right on top of the headunit. Should i change it?
Posted Dec 21, 2018 · 19:53 UTC#4
Should be fine as long as you used the provided metal sheet under it. Mine sits outside of the dash in the center, against the windshield and doesn't look bad imo
Have you tried the reset?
Posted Dec 21, 2018 · 20:17 UTC#5
i have, same thing. My sits on the dash without the pad, maybe that’s why. Imma switch it to see if it works
Posted Dec 22, 2018 · 09:26 UTC#6
Update so  it was fixed momentarily yesterday after i changed the location. Today, the problem can’t back, should i change the antenna?
