AVH-W4400NEX stuck on black sceen or reverse camera
By flagnation · Jan 10, 2019in NEX Series💬 5 posts👁️ 4,074 views
Posted Jan 10, 2019 · 10:07 UTC#1
Hi,
I just installed a Pioneer AVH-W4400NEX. Since the backup camera didn't come on when I put the car in reverse, I did some changes in settings. However, now when I start the car all I see is a black screen when in drive and park or the reverse camera when in reverse. This is brutal. How can I get back to the main menu and fix this issue? I tried pressing and holding each button and also pressing on the screen but nothing worked so far. Any help would be greatly appreciated. Thanks in advance
Edited Jan 10, 2019 by flagnation
Posted Jan 10, 2019 · 12:30 UTC#2
You have the setting for camera as Ground. Switch to postive.
Posted Jan 11, 2019 · 00:18 UTC#3
How do I get to the main menu?
Posted Jan 11, 2019 · 08:08 UTC#4
Put the car in reverse. And go through the menu.
Posted Jan 15, 2023 · 01:23 UTC#5
Bonee - thank you SO MUCH!  I have the same head unit and finally got my camera successfully installed and had the same issue!
I would never have figured it out - Thanks again!
