No GPS warning
By nissanfrontier · May 11, 2019in Problems/Troubleshooting💬 4 posts👁️ 1,890 views
Posted May 11, 2019 · 17:26 UTC#1
 AVIC f150
Anyone ever get this warning but the GPS still appears to be working fine
I did disconnect the wire to move the antenna block on my cowl, when I plugged it back in I got this.  But the GPS still appears to follow my tracks and direct me to places i need to be
Posted May 12, 2019 · 03:48 UTC#2
If you have your AVIC-Z150BH hooked up completely, you have both the 1) car speed signal input*, and 2) reverse gear signal input*.  With those two wires, the system should operate without a GPS signal.
My guess is that you have those two wires connected and may have a poor connection (e.g. loose connection, et al) to the GPS antenna.  You can find information on the GPS signal on the Information Screen.
* Some installers unfortunately neglect to connect them.
Edited May 12, 2019 by bitmap
Posted May 12, 2019 · 15:48 UTC#3
11 hours ago, bitmap said:
If you have your AVIC-Z150BH hooked up completely, you have the both 1) car speed signal input*, and 2) reverse gear signal input*.  With those two wires, the system should operate without a GPS signal.
Yes, between speed sensor, knowing whether the vehicle is going forward or reverse, and the inertial guidance (senses turns and even inclines) your GPS's dead reckoning will do a pretty good job estimating your vehicle's position. However it will eventually drift off. Last year while not actually navigating by GPS, I glanced at my map display and saw my car's position was on the wrong side of a  river. However the speed and turns matched my driving.  When I got home I had to re-position my GPS antenna to a better spot under my cowling - it seems it slipped too close to the firewall.
Posted May 13, 2019 · 19:42 UTC#4
Thanks guys. I think I figured it out. I removed the green connector and rotated the connection slightly and reinstalled. this seems to have returned GPS signal back.
