Backup camera guidelines on by default?
By shaker281 · May 24, 2019in NEX Series💬 5 posts👁️ 1,756 views
Posted May 24, 2019 · 07:00 UTC#1
I have the c2550-NEX. I have to touch the guidelines icon each time I put the car in reverse. Is there a way to make the guidelines on by default as soon as I put the car in reverse?
FYI: I am using the Pioneer's guidelines, not the camera's guidelines.
Posted Sep 02, 2020 · 06:07 UTC#2
did you ever figure this out?  I have an AVIC-8600 NEX and have the same issue.
Posted Sep 02, 2020 · 12:20 UTC#3
should be in the settings to have it on.
Posted Apr 03, 2021 · 17:49 UTC#4
Did u try to reverse the settings of the camera from ground to battery and vice versa?
Posted May 07, 2021 · 22:02 UTC#5
I did, and that did not work.  I can manually turn the lines on, but by default they are off.
