Hi,
I recently installed a new AVIC 5100NEX and I immediately noticed the classic low-level engine/alternator whine coming through my front components (which was not present through my old radio). I had read about some Pioneer decks not having proper RCA grounding so I wrapped copper speaker wire around the barrels of the RCA outputs and then grounded that to the radio chassis. This seemed to take out the constant whine but there sometimes now is a very low intermittent static-type noise (thankfully barely noticeable unless you're sitting still and there's no music playing) and now it is doing the whine ONLY when I have the headlights on. It seems like the whine fades in as the radio screen slowly dims when the headlights are turned on.
I am aware of the whole pico fuse dilemma but I do not remember hot swapping any RCA's when installing the radio. I also checked the resistance of the ground wires to my amps and to the radio and they all read 0.00 ohms, and my RCA's and power cables have very little contact with each other. What am I missing? Do I need a noise filter somewhere before the radio? Could it really be the pico fuse and now I'm stuck with a whiny new radio? Help please! Thanks
