Same harness for NEX8200 as NEX5000?
By cgjamj · Jun 15, 2019in NEX Series💬 7 posts👁️ 1,117 views
Posted Jun 15, 2019 · 15:16 UTC#1
I have an NEX 5000 and since a couple firmware updates ago (can't remember which one), part of the screen is unresponsive intermittently and requires repeat touches to acknowledge. Therefore, I'm considering buying a used 8200 and I'm wondering if this will be a pretty simple swap? It looks like most things have the same exact connection, GPS antenna, remote, etc. But I'm mainly curious if they're using the same harness where I could just simply wire the speaker connections and plug the 8200 in with the existing harness.
Thanks in advance!
Posted Jun 15, 2019 · 16:29 UTC#2
Everything is same
Posted Jun 15, 2019 · 16:52 UTC#3
Thank you!
Posted Jun 27, 2019 · 18:43 UTC#4
Everything is the same, but the 8200 wire harness has the remote control wire added. If you're upgrading from a 5000 everything will work the same except the hand held remote.
Posted Jul 15, 2019 · 19:16 UTC#5
Thanks a lot. That's good to know. I don't believe the 8200 I bought comes with anything other than the wiring harness which I won't even need since I'll use the existing harness...so I don't think the remote wiring would even be an issue. If he does send it, I'll consider using the 8200 harness and rewiring.
Posted Jul 18, 2019 · 01:04 UTC#6
they are completely the same!!!
everything will work as before
you do not need to change the wiring
Posted Jul 20, 2019 · 11:29 UTC#7
Yep! I swapped it out and it was literally plugging everything thing in and all was good. Thanks!
