Radio static d3
By workings · Sep 29, 2007in Problems/Troubleshooting💬 14 posts👁️ 2,379 views
Posted Sep 29, 2007 · 18:02 UTC#1
Installed the d3, all is fine except for one thing, no matter how my wiring is conf. behind the unit I can not get a good reception on my radio stations. (lots of static)
I even unpluged the nav. wire to see if that would help nothing there, I also tried moving my pac swips module, could it be a ground issue, I used the ground from the car plug for all. (radio, pac, bypass)
This happens with or without the car running. (2003 Honda Pilot)
Posted Sep 29, 2007 · 18:14 UTC#2
Did you plug in your vehicle's antenna to the d3?
Posted Sep 29, 2007 · 18:34 UTC#3
Yes...all I get is one strong station on fm, must be close in range...thanks
Posted Sep 29, 2007 · 18:36 UTC#4
I would check to make sure you don't have an amplified antenna system on your pilot. sounds like it might need to have the power antenna wire connected.
Posted Sep 29, 2007 · 18:46 UTC#5
There was another plug on the stock radio with only two wires, I thought that might be for the anti-theft funtion.
Any help on finding the right wire to connect the blue wire to...thanks
Posted Sep 29, 2007 · 18:57 UTC#6
Ok, there is a blue wire on the d3 harness, and a blue wire on the metra harness that plugs into the pilot harness, could it be that those two should be connected...I thought that was for a power antenna that retracts.
Posted Sep 29, 2007 · 20:02 UTC#7
Problem solved, when all else fails read the directions...the blue wire has to be hooked up when you have a window antenna...it requires a antenna booster and the blue wire makes that all work............
Thanks for the replies.....
Posted Oct 10, 2007 · 17:50 UTC#8
i have the same problem with my radio being unclear and having a lot of static/ weak signal. did connecting the 2 blue wires fix the problem completely? does the radio sound normal now?
Posted Oct 10, 2007 · 19:50 UTC#9
Yes it did in my case, if you have the same vehical it should be your fix as well...that of course , not knowing all of your details.
Posted Oct 18, 2007 · 04:10 UTC#10
I wonder if your solution will work with my 4 runner?
Posted Oct 18, 2007 · 04:23 UTC#11
sometimes the honda antenna adaptors suck real big even if you hook em up right
Posted Nov 17, 2007 · 01:44 UTC#12
Circuit City did my original install of an eclipse AVN6610, and there was a lot of static on the FM radio, so much so that it was useless. I hated the 6610, so I swapped it for the D3, which is much, much better. Quick question, does the blue wire for the honda antenna adapter go to the remote lead or is that power? They had it hooked up to the remote lead on the eclipse, and I did the same on the D3. I even replaced the antenna adapter.
Posted Nov 17, 2007 · 01:53 UTC#13
for my old N1 I had that problem, I sent it to pioneer for the flex cable thing. and they told me I also needed a new AM/FM Tuner, which I didn't pay for because 200 bucks is not worth it.
Posted Nov 17, 2007 · 01:55 UTC#14
Right but I don't think that's the problem. I just read through the D3 manual, and it tells you to not use the remote wire that is associated with the aftermarket amps for the antenna lead, and I recall the Circuit City had the antenna wire split. The antenna booster wire from the D3 is split to go to the antenna, and to go to the blue wire coming out of the factory adapter harness. I don't think the blue wire has to go to the factory harness adapter, right?
Could that be my problem? Seems a bit weird.
