Have problem with my Z1 with bluetooth to match up with my Cingular Sony Ericsson W810i. The phone is coming back saying access denies by other device. Can anyone help
Posted Sep 30, 2007 · 00:12 UTC#1
did you put both devices in pairing mode?
How do you put the Z1 in pairing mode
it is in the phone menu
When I go into the phone meun the only thing i can pick is phone numbers everything eles is grayed out. Also the blurtooth I have is the ND-BT1
well then it sounds like you have not done the bypass so you will have to put the ebrake on.
Thanks that worked
