vss help for a 1986 Ford LTD
By mustangwally · Sep 30, 2007in Vehicle Specific Wiring💬 3 posts👁️ 716 views
Posted Sep 30, 2007 · 05:10 UTC#1
i have a 86 LTD that i require help to hook up the VSS wire and the reverse wire as well
thanks in advance!!!
Posted Sep 30, 2007 · 06:26 UTC#2
See if you can get behind the gauge cluster. If there's a cable connected to the speedometer, then there is no vss wire in the car. You'd need a speed pulse generator.
Posted Sep 30, 2007 · 15:46 UTC#3
thanks!
