No speed display and speed pulse doesn't work on N3??
By snowmanx · Oct 06, 2007in Problems/Troubleshooting💬 3 posts👁️ 812 views
Posted Oct 06, 2007 · 10:19 UTC#1
Just had my unit professionally installed, it's a AVIC N3 into a Dodge 3/4 ton Quad cab truck.
I had them do a bypass so that all functions work while driving and everything works except the speed display underthe vehicle dynamics.
The other thing that doesn't seem to work is the speed pulse. The installer swears it's installed right and can't figure it out.
Tech support says it's a bad unit????
PLEASE HELP me get this fixed.
Posted Oct 06, 2007 · 15:25 UTC#2
ummm what year dodge? if its 04 and up then there is no speed pulse in your truck. youll need an adapter to get vss from the can-bus system.
as far as ur speed reading ive gotta 06 megacab with no vss or reverse hooked up and everything works great.
Posted Oct 06, 2007 · 21:37 UTC#3
It is a 2005...where do I get an adaptor from...and are you sure there is no speed pulse??
Is it hard to hook up?
