I have an LG-VX9900 from Verizon and cant pair with the BT200. My phone recognizes the bluetooth on the unit but fails when I enter the 0000 pair code. Has any one been successful?
T99VZV02
T99VZV02
i have the same phone and it works great on my bt200....well for the most part. you have to put the phone in visible mode in order for the pioneer to find it. go to bluetooth menu then hit options, then discovery mode and put it on visible. then after you turn that on, then search for the phone on the avic. it should find it and after you put in the four 0s , then register the phone on the avic to save it. thats what i did on mine and it always recognizes the phone when i turn on the car.
if not, then try resetting the bluetooth adapter.
Thank you, thank you, thank you. It worked like a charm. I never saw the instructions on putting the Envy in visible mode. I was so frustrated that I started looking for the receipt to take this phone back.
Doug
One remaining problem I'm encountering is setting it up so the units pair/connect automatically. I have to go through the whole process each time.
Doug
Has anyone paired the audio side of the LG VX9900 to the avic-d3 via the bluetooth device? I got the phone to connect but not the audio.
I AM HAVING THE SAME PROBLEM WHICH IS REALLY FUSTRATING. EVERYTHING WORKS EXCEPT THE AUDIO. DOES ANYBODY OUT THERE HAVE THE ANSWER??????
IF SO EMAIL ME AT THE FOLLOWING EMAIL ADDRESS: [email protected]
