Crappy install kit!!! Front panel catches on trim ring Z2
By cuendet · Oct 06, 2007in Problems/Troubleshooting💬 12 posts👁️ 1,708 views
Posted Oct 06, 2007 · 19:44 UTC#1
Got my SRT8 back from the install shop - HORRIBLE kit!! When the front screen is opening, it catches on the trim bezel and stays at half open (or half closed for the optomists here) ... I looked to see what it was catching on and found it, then GENTLY lifted up on the bottom of the unit and VIOLA! it opened. I have the SCOSHCE install kit for a 2007 Dodge Charger, and upon looking at it, it's a POS made of plastic and the unit is hardly secured!!!! I pushed on it to test its strength only to have pushed the unit back in the dash. Took it out, worked on the screws, etc...still it doesnt hold the unit securely at all.
What otehr kits that are STRONGER than this piece of crap are out there for a 2007 Dodge Charger SRT8 with an AVIC Z2 radio??
Thanks in advance for ANY help!!
Posted Oct 07, 2007 · 08:27 UTC#2
Should have tested the unit before LEAVING the shop.
Lesson learned Daniel-San.
Posted Oct 07, 2007 · 12:49 UTC#3
I did, the UNIT is fine, opened fine, plays fine, sounds fine ... after I drove the car for a bit, THEN tried opening the door is when this happened, the door remains half open unless I lift the unit up, which has about 1/16th" of play - shouldnt the unit be firmly secure w/o ANY movement?? The Scosche kit is the issue, cheap plastic snap in parts, that's why I'm looking for a metal cage of some sort, probably have to make it myself since nobody else seems to have a suggestion
Posted Oct 07, 2007 · 14:20 UTC#4
take it back and tell them to fix it
Posted Oct 10, 2007 · 12:49 UTC#5
Super glue is my friend when assembling these kits. I use Zap green and the spray activator (found at hobby shops) on all joints that will never need to come apart. (You don't want to trap your head unit in the kit forever) Just be careful if you use the spray activator, it will change the sheen on your kit, so block off what you don't want to look wierd. Oh, and the fumes will burn the hell out of the inside of your nose. Also, make sure the kit is mounted properly. If you still want abetter kit, try the Best Kits BKCDK-650. It's a good-looking kit, and strong....
http://www.bestkits.com/SearchResults.a ... 20-%202007
Posted Oct 10, 2007 · 14:05 UTC#6
I'm with Jimmy on the glue. I have Metra products at my shop (both the kit and the glue/activator) and have been happy with the results for both. If you are still worried about movement you can backstrap the unit more securely in the dash. If you are still not happy with the results my last suggestion would be to take it to a machine shop or good welder in your area and have some custom metal brackets made to secure the unit in the dash to your likeing. Probably won't be cheap, but will be the only "metal" way to secure the unit as there is no "metal cage" available for your car that I am aware of.
Posted Oct 10, 2007 · 17:08 UTC#7
so did your srt8 have the huge factory navi in it already? or did they make you go and buy the bezel?
ive found that its alot easier to build a double din kit than it is to make any double din look good in a metra kit. id like to see what unit they use as reference on the cutout for the double din. d3's fit fine but any z series always takes modification.
Posted Oct 11, 2007 · 14:36 UTC#8
The dash kit mounts directly to the dash support, not the trim bezel, so I am a bit confused as to how the unit is flopping around in your dash. There must be something very wrong....
Posted Oct 11, 2007 · 20:43 UTC#9
I bought the Metra kit for my Z1 install. I never thought of using crazy glue....
Did the screws that it come with work for you all? I had to find screws in my garage and cut them down in order to get this installed. If not - what screws did you guys use?
When I take my deck out this weekend - I am going to glue EVERYTHING on that plastic kit!
Posted Oct 11, 2007 · 20:49 UTC#10
the screws come with the pioneer not the dash kit xx
Posted Oct 11, 2007 · 20:57 UTC#11
I tried to use those - but they werent long enough. I used the Metra kit for a Ford Fusion.
Posted Oct 12, 2007 · 16:46 UTC#12
I try and swipe the screws from the brackets on the factory radios in F-250/350's since they were my most common install.....
