Rear veiw in map mode
By danman · Oct 07, 2007in General💬 6 posts👁️ 1,345 views
Posted Oct 07, 2007 · 01:17 UTC#1
Is the any way to cancel the twin map veiw?so its a full screen instead of cut in half
Posted Oct 07, 2007 · 01:34 UTC#2
you can put the reverse wire on a switch and view it on full screen
Posted Oct 07, 2007 · 01:55 UTC#3
if you put the switch in make sure you diode isolate the wire from the car (reverse wire), so the reverse lights aren't on while you are driving forward 8)
dave
Posted Oct 07, 2007 · 20:48 UTC#4
cool,where should i splice the switch in?yeah,that twin map is good but it sucks you cant disable it somehow
Posted Oct 14, 2007 · 03:56 UTC#5
Subscribing to this. I've been wondering the same thing.
Posted Dec 04, 2007 · 23:42 UTC#6
You really dont even need a diode if you use a SPDT switch.
Just wire it like below. If you have backup lights that work off ground instead of 12 volt then you need to wire the switch accordingly.
