02 chevy Trailblazer
By brianas · Oct 07, 2007in Vehicle Specific Wiring💬 5 posts👁️ 1,457 views
Posted Oct 07, 2007 · 13:14 UTC#1
Hello,
looking for VSS and reverse wires
on 2002 chevy trailblazer
also , is there a DblDin install kit needed
for this vehicle?
thanks
Josh
Posted Oct 09, 2007 · 17:26 UTC#2
VSS is green/white @ pcm drivers side eng compartment.
Rev lt is lt green @fusebox under rear seat. :D
Posted Oct 09, 2007 · 17:28 UTC#3
the vss is in a blue plug pin 32, rev lt is +.
Posted Oct 09, 2007 · 21:03 UTC#4
Can also find vss in the plug going to the cluster, green/white in the 4th position in (only green/white in a 4th pin in). Rev should be lt green at the rev light. And yes, you need a dash kit to mount the unit. I use a metra 99-2003. You will also have to trim a bit of plastic inside the dash to make room for the new unit.
Posted Oct 13, 2007 · 15:00 UTC#5
thanks alot,
the VSS was right at the cluster-made it much easier.
had to get the REV at the fuse blk under rear seat.
suprised i couldnt find the REV up front any where-
yes i did need to trim that brkt support for the factory radio
easy one - for once - took 30 secs with dremmel
the fit and finish with the metrakit to chevy was really
not the greatest- but that seems common on the gms
thanks
Josh
