New Firmware / Bypass issue
By aspendog · Oct 08, 2007in Problems/Troubleshooting💬 3 posts👁️ 995 views
Posted Oct 08, 2007 · 20:02 UTC#1
Not sure if this has happened to anyone else but I updated my wifes pre june Z2 to allow the bypass and then again w/ the new firmware to fix the "hot start" issues. I was driving with her yesterday and went to type a destination and I was "locked out", I began to watch and it would flicker on then off... There is no parking brake warning. The unit seems to just be switching itself back an forth, no rythm or sequence... I have not pulled it yet and think it is the "1st wire", if it was the 2nd wire wouldn't I be getting a parking brake error? It has got to be the 1st wire because even when parked and parking brake on it still does it... I'll update after inspecting... Anyone had this happen?
FYI The unit was bypassed w/o issue prior to the firmware update, I'm not convinced it has anything to do with the update as I have noe even checked the bypass connections yet...
Posted Oct 08, 2007 · 20:10 UTC#2
Probably a loose pin in the "bypass" hole, or a loose ground. Happens often on this board for some reason
Posted Oct 08, 2007 · 20:15 UTC#3
Thats what I figure but I expected to see a "parking brake" error...
