D3 image replacement via edited DVDs
By Camelot One · Oct 09, 2007in Hacks/Mods💬 6 posts👁️ 1,863 views
Posted Oct 09, 2007 · 05:52 UTC#1
If this has been discussed, forgive me. A search turned up nothing.
I want to replace the Ipod image on the D3. The issue for me isn't the layout, it's that the background has what looks like defective screen lines through it. Yes, I'm sure it's just that image, everything else on the unit looks fine.
Based on my quick view of one of the discs, it looks like the general background images are all there, stored in induvidual colors. But I don't see any of the default - changed by changing layout color images on the disc, and I assume the ipod image will be one of them. With everything else loading from the DVD, I find it hard to believe those images are hard coded into the unit. My working theory is that the defaults are loaded into the unit, and future updates will load off of the revision 2 disc. So the issue is just figuring out where they would be stored, and by what name. (if my theory is right anyway)
Before I start blindly testing, has anyone else tried this? Any tips or info would be helpful, even if not directly related to the ipod image itself. I'm trying to draw as much as I can from the D1/2 hacks.
Posted Oct 09, 2007 · 05:56 UTC#2
Why don't you just change it to one of the other backgrounds? Or better yet, make a custom one?
Posted Oct 09, 2007 · 06:02 UTC#3
I haven't found any way to change it to another background. (thats what I'm trying to do)
This is the image I'm trying to change: http://www.pioneer.eu/images/eur/AVICD3iPod.jpg
I found an earlier thread on the subject, but it died without any answers.
Posted Oct 09, 2007 · 06:40 UTC#4
I think it changes to whatever you default it to. Go into the nav menu, press settings, press background picture setting. Change the one for A/V. If you don't like any of those, you can upload your own via CDR
Posted Oct 09, 2007 · 07:05 UTC#5
I've tried that. When you use "hide", the updated image shows. But as long as the ipod layout is up, it displays a different image. (looks like a spinning CD on the left side)
Posted Oct 09, 2007 · 07:17 UTC#6
That part you cant change. Its not considered the background, its part of the ipod info screen and it is set in the software.
