Difference in harnesses between D1 and D3?
By BiggSean · Oct 10, 2007in General💬 7 posts👁️ 886 views
Posted Oct 10, 2007 · 03:33 UTC#1
Hey guys, I currently have a D1 installed in my Subaru WRX along with the XM receiver. Does anybody know if the harnesses/connections are the same between a D1 and a D3? I'd like to be able to keep my XM receiver, and add the newer ipod adapter, and the bluetooth adapter. If the harnesses are the same I could simply pull out the D1, and replace it with the D3, eliminating the need for me to rewire the whole thing.
BTW, here's a gratuitous shot of my interior. :)
Posted Oct 10, 2007 · 04:16 UTC#2
Nope. Different harnesses. Your rewire will require cutting about 12 wires, and re-connecting them to the same color ones on the D3 harness
Posted Oct 10, 2007 · 04:22 UTC#3
Ok, that's easy enough. If they are color-coded it should be a no brainer.
Posted Oct 10, 2007 · 17:20 UTC#4
I like the Defi setup, I was thinking about those but the cost was a bit high for me, after the UTEC, exhaust, swaybars.......
Posted Oct 10, 2007 · 17:27 UTC#5
I actually sold the DEFIs that you see and switched over to amber 60mm gauges, along with an STI cluster. This is one of the main reasons for me wanting to switch over to the D3, for my ability to match the STI cluster/amber defis.
These cars are definitely very addictive, and expensive to mod. Here's my current project I'm working on:
Fully built STI long block
kelford AVCS 272 cams
Perrin GT35R kit
Hydra
Hydramist
Perrin EL headers
Koyo radiator
Perrin fuel rails
Dual walboros
SPEC c intake manifold (no tgvs)
JDM 12mm oil pump
I'm sure i forgot a million other parts, but we are shooting for 550awhp with this setup.
Posted Oct 10, 2007 · 17:48 UTC#6
I went with autometer gauges and a modified factory gauge pack, I used the red bulb covers and have my D3 set to red.
Posted Oct 10, 2007 · 18:07 UTC#7
Nice 04 STI. ;)
Check out my website if you have the chance:
www.wrxmodders.com
Sign up and post in the newb introductions section. :)
