im hella comfused. i downloaded thestuff and burned it and put it in and hit the reset and nothin happened. if there is some one in or around salt lake that could help it would awsome.
Posted Oct 11, 2007 · 06:06 UTC#1
Just order it from Pioneer man
i just checked its like 250 for the disks. is there any other way to get it.
If you want Z2 maps, its $250 for the disks or hack your HD like the instructions here state.
If you just want it bypassable, and are not capable of burning the disk yourself, call Pioneer and tell them your unit is freezing on the splash screen. They will send you a disk to fix that, that also happens to make your deck bypassable using the 2-wire method
i got my cuz to do it for me, when i put the disk in it says the disk is already updated. doesthatmean im good to go? thanks for all the info
Ya. Just have to do the 2-wire bypass
