No AM Reception
By cwirth · Oct 13, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,084 views
Posted Oct 13, 2007 · 01:29 UTC#1
I just finished installing a D3 in my Toyota Matrix. Everything went well including the bypass. I also installed XM. The Nav, FM and XM works well. However, I have no AM reception at all. I made sure the vehicle's antenna lead was securely plugged in. FM works well but not AM. The antenna is roof mounted. I did not connect the blue wire on the D3 harness. Does this need to be connected? I thought it was for a power antenna. Any suggestions on what to check?
Posted Oct 13, 2007 · 07:23 UTC#2
There's still stations that broadcast on AM? And there's still people that listen? That's crazy...
But anyway... Some cars' antennas have factory signal boosters on them, which require the antenna turn-on lead be wired up to them. Check that out.
Posted Feb 23, 2008 · 05:25 UTC#3
Explain that in English, because I'm having the same problem. :)
Posted Feb 23, 2008 · 20:05 UTC#4
I have the exact same problem in my Audi A4.
My second installer (who fixed up the mess the first guy left) used the METRA-40EU55 antenna adapter. It powers the factory antenna and gives good FM reception, but no AM. I think it may be that there's simply no way to get it connected properly using existing antenna adapters.
Posted Feb 26, 2008 · 04:58 UTC#5
I am having the same problem on a Infinity QX4 2001. However, i get the reception but it goes in and out , its not listening friendly. Any ideas ? help ?
Posted Feb 26, 2008 · 14:12 UTC#6
In my Audi, the factory antenna cable ends in a little cream-colored plug with *two* RF plugs on it....presumably, one is AM and the other is FM. However, every Metra antenna adapter kit I can find has only one plug on it, so it appears a splitter is needed....not sure what kind of splitter to get, but I don't care about AM anymore, so I'm not bothering.
