I am getting an Alpine 701 processor, and I would like to use the digital output on the Z2. I know there is a little box that connects to the z2 to change to an optical out. Can you get the box by itself, and will it work?
Anyone found a way to use the digital output?
Only an Alpine will control an Alpine processor
I want to use the digital out of the z2 to the digital in of the 701. There is a separate controller for the alpine processor
I just ordered the box from pioneer. CXC3584. Should get here soon. Should allow me to use a toslink optical cable to connect to an external processor. This will alleviate the 2 volt preout issue, and decouple the headunit electrically to reduce system noise. Ill post back when I know it works.
Did you ever get this to work?
Am am looking at the same set up... Z2>h701
any updates? Does this work?
Well... not only did the processor not work, but it has totally proprietary cabling / interfaces.
So... I hooked it up through rca's and the system sounds phenominal after weeks of tuning. The only issue really is dual volume controls. I have not been able to fix one of the volume controls because of the feedback issues with the bluetooth.
