HELP! "Cannot use HDD"
By kouka · Oct 13, 2007in Problems/Troubleshooting💬 12 posts👁️ 3,770 views
Posted Oct 13, 2007 · 11:44 UTC#1
turned on my z2 and it says:
Cannot Use HDD.
Disque dur inutilisable.
HDD kann nicht verwendet werden.
anybody know whats going on?!?!
ps: i have a stock harddrive in the unit
Posted Oct 13, 2007 · 17:38 UTC#2
did u mess with ur HD ????
did you mess with test menu
more info so we can help
Posted Oct 13, 2007 · 19:45 UTC#3
did the 2wire bypass and the bypass update wasn't needed, didn't mess with anything else. last thing i did was stick a few cds in so it would copy them, next time i turn it on i get this message?
Posted Oct 14, 2007 · 02:47 UTC#4
well thats odd
all i can tell you is send it back to pioneer or replace the HD at ur own cost
of find some 1 with HD to try on ur unit
Posted Oct 15, 2007 · 00:16 UTC#5
so i fired up the unit again this morning and it worked fine again???? weird... anyways thx for the help...
Posted Oct 30, 2007 · 23:52 UTC#6
Grrrrrrrrrrrr
bad karma !!!
mine just did thae same thing today :(
im hating Pioneer :x
along with all the engine noise i just got today
its @ pioneer repair alredy
this flipin unit spends more time @ pioneer then in my car :(
Posted Oct 31, 2007 · 13:45 UTC#7
Yeah, mines been doing weird stuff too lately. Ever since I got it transplanted from my camry to my xb its occasionally not booted up correctly. It will sit with a black screen, and i can just hear the radio station I had it on prior to turning off my car. Then I'll turn my car off and then back on, and it will be fine again.
But, electronics are weird and are almost never perfect, so I just let it go.
Posted Nov 06, 2007 · 14:50 UTC#8
i would remove the drive and run a utility like SpinRite on it (on the stock drive it will take many hours) and find if the drive is failing. If it is failing, take it as an omen and clone that puppy to a better/bigger/faster drive!
Posted Nov 06, 2007 · 16:39 UTC#9
I'm almost 100% positive that your problem has something to do with it being too cold....I remember reading it in the owner's manual...
Check the index in the back of the manual, there are 3 pages for Hard Disk....I thnk it's like page 192'ish...
Posted Nov 06, 2007 · 18:57 UTC#10
I always thought the cooler the temp, the better eletronics works. For example a computer, it would always run faster with a better cooler.
Posted Nov 06, 2007 · 19:08 UTC#11
I believe 72F is where temps need to be for pretty much all electronics....
Cold is actually worse....because once you start to use the electronics, the component's temps will raise, creating condensation... Water will create shorts as well as rust...
Posted Jan 22, 2010 · 01:25 UTC#12
Now this is getting really strange. I am a firm believer that even with electronics, there must be a reason for an intermittent problem.
I have an AVIC Z2 that I had professionally installed about 2 and a half years ago. It has the bypass, everything about the bypass was working fine. It had some minor glitches (sometimes would not accept a CD, had to pull over and turn engine on and off before it accepted it), but 3 days ago it wouldn't boot up, just showed me "Cannot use HDD".
I tried as many resets as it would let me do without actually working, then decided my HDD was toast, and maybe that is the weak link of the AVIC Z2. I was looking for replacement units.
Then today - THREE DAYS LATER - I started my 4Runner and it booted up just fine, even had all the stored memory in the Music Library.
I live in California, and it was between 60 and 65 degrees when it happened, and when it started working again.
There has to be a logical explaination. I didn't use anything any differently when it went bad from the way I have been using it for the past 2 and a half years.
