Can someone take a picture of where they placed their bluetooth unit. or give a good description
Thanks in advance
Posted Jul 13, 2006 · 21:25 UTC#1
MacFly said:my installer told me that there is a second unit that has a Call / End button that has to be mounted? is this true?
from the sounds of it, there's only once piece that needs to be mounted and it's not a Call / End unit.
thanks
bongus said:MacFly said:my installer told me that there is a second unit that has a Call / End button that has to be mounted? is this true?
thanks
Obviously your installer has not installed one of these units before. The BT unit is just one plug that connects to the Z1. There is enough cable included with the unit that you can find a place to mount pretty much anywhere behind the HU. Everything in regards to the BT module is controlled by the Z1...all call and end buttons are on the HU. There is an optional IR remote (here is a link) that has the buttons that your installer describes but it is not required to use the BT module. Hope this helps.
