Possible problem with d 3
By kruff10 · Oct 15, 2007in Problems/Troubleshooting💬 4 posts👁️ 636 views
Posted Oct 15, 2007 · 13:19 UTC#1
I have the d 3 installed , can it have a adverse affect on the speed odemeter in my ride?
Posted Oct 15, 2007 · 13:28 UTC#2
the problem i`m having is that the speed odemeter stays at 60 mph when im standing still and goes up to 100 mph when im only going like 50 mph, could this be releated to the d 3?
Posted Oct 15, 2007 · 13:51 UTC#3
The only way the D3 could affect your car's speedometer would be if you hooked the wrong wire from the D3 to the car's VSS wire? Just a guess, really. But if you hooked everything up right, it shouldn't cause that to happen. Unless there was something wrong with the unit itself, like it was sending voltage out through it's VSS wire for some reason.
The only way to find out would be to disconnect the D3's speed signal wire from the car and see if it fixes the problem. If it doesn't, the problem lies somewhere else.
Posted Oct 15, 2007 · 13:58 UTC#4
thanks
