AV Input Problem
By Guest · Jul 13, 2006in General💬 2 posts👁️ 640 views
Posted Jul 13, 2006 · 22:30 UTC#1
Ok, i have everything hooked up (except the VSS wire and reverse - which aren't necessities) and everything works great.
Then I decided that I would hook my iPod Video up to the AV Inputs on the back of the Z1. Hooked everything up, and i can't select the AV button. Is there a reason for this? I am a little frustrated.
Thanks for all your help.
Posted Jul 13, 2006 · 22:49 UTC#2
The AV button on the front of the unit to the left of the MENU button or the AUX input that your video ipod is connected to?
If you can't hit the (real) AV button on the front of the unit left of the MENU button, then there are big problems, I don't know what to do with that.
But if you mean the "soft" AUX button is grayed out and you can't select it, you have to enable it, go to some AV function that works, then AV Settings, and it's not in the audio settings, but the system settings in there, I think you have to enable it so it "knows" there is an input on that aux in.
