Planning on upgrading from Z1 to modded Z2 image...
By docluv01 · Oct 16, 2007in Hacks/Mods💬 5 posts👁️ 1,098 views
Posted Oct 16, 2007 · 14:17 UTC#1
Hi Guys,
1st I do apologize if this has been answered before. But I have a Z1 with the ducati flasher bypass circuit, worksd great. I was going to do the hard drive "upgrade" that has been discussed in this forum, hence I would need to do the 2 wire bypass.
I have a need to take my car back to the shop to have them fix something non related. I was thinking if they happen to have my dash open, the could do the 2 wire bypass for me.
My question is, is it possible to have both the ducati boy circuit AND the 2 wire bypass on the unit? This way giving me the option to do use either image? I will be upgrading the hard drive image this weekend, but tryign to avoid havign to pull my dash out again, as its a pain in the a$$ to remove the ducati boy circuit.
thanks in advance!
Posted Oct 16, 2007 · 16:56 UTC#2
Just do the 2-wire bypass now. If you do either last years bluetooth update, or this years firmware update to fix freezing, it will disable the flasher bypass anyway and switch it to the 2-wire. So you are set to go when you decide to mess with your HD
Posted Oct 16, 2007 · 23:59 UTC#4
You're makin it too easy for em. If they look around, they might learn something and save us from thousands of other repeat questions :wink:
Grrrr post this for them i hate folowing you around lol
http://www.sminntech.com/z1flash.html#newbypass
Posted Oct 17, 2007 · 03:50 UTC#5
And you give them too much credit :roll:
