Possible to take a Z2 and and run a clone of HD3 soft in it?
By ozdude · Oct 18, 2007in Hacks/Mods💬 20 posts👁️ 5,550 views
Posted Oct 18, 2007 · 07:52 UTC#1
Hi guys, I'm in the market for an AVIC here in Australia. However, since I've learned the HD3 version we have here is priced at an outlandish RRP of $A3800($US3400), I naturally started to think about ways around it. Knowing the units are based on the same platform, has anyone tried to swap out the drive in a Z2 and replace it with another drive with an image of HD3(any version)? I can easily get a hold of the HD3 drive from a friends unit and clone it. This would save me just under $2k, so obviously well worth the exercise if it's at all possible. Heck, I'd even consider buying a refurb unit cheap on ebay just to test theory myself if no one knows for sure. I can always re-sell it if it doesn't work.
Posted Oct 18, 2007 · 14:04 UTC#2
well in theory, if you can get your friends HD3 and remove and unlock the HDD without erasing the data, then you can clone the image and put it into your own new drive. and just install it into the new avic. But since I have never seen your HD3 version, it's just a theory. If you want to play around with it, go for it... and let us know how you did.
Cheers from Canada :):):)
Posted Oct 18, 2007 · 18:15 UTC#3
post the image ill try it here save you money and time
Posted Oct 19, 2007 · 00:35 UTC#4
Great idea, thanks. How big is the image from an AVIC approx? Also being as I would have just cloned the image with something like HDClone, what is the best way to create an image instead? Norton Ghost?
We'll focus on getting the drive unlocked at this end and then take it from there.
Can anyone suggest an easy place to upload an image to also?
EDIT: I have another idea which should prove the same thing more or less. I'll take the Z2 drive image and load it on a fresh drive and see if it works in the HD3. That would save several steps and pretty much prove compatibility. Next thing, the one thread that talks about the image mentions a possible image on usenet, but I can't find the group any more. I use usenet every day so that would be a piece of cake and the easiest method to get the image.
Posted Oct 19, 2007 · 02:34 UTC#5
lol yaa that can work also
Posted Oct 19, 2007 · 02:51 UTC#6
Ok seems the FTP version of the Z2 image will do just fine. I'm going to get cracking on it later today and hopefully we can try it over the weekend.
Here goes nothing!
8)
Posted Oct 19, 2007 · 10:22 UTC#7
Here goes nothing!
8)
Problem is of course that the radio part of the HD3 is completely different from the Z2, whilst you will probably also have problems with regional codes for the DVD....
re. the map database, I don't know in howfar they are compatible...
Posted Oct 20, 2007 · 01:02 UTC#8
Here goes nothing!
8)
Having used a lot of US headunits here over the years, what are the differences in the radio part going to do? I have had a few people tell me that US heads have different tuners in them. However, in operation I've never had an issue going back as far as 15 years with using them here. Perhaps its more of an issue in Europe.
I was under the impression that region coding was hackable with the AVICs. For general DVD playback, which I nearly never use and less so as I'm actively replacing my library with High Def discs, it's not a huge issue. In fact with my previous car's factory DVD player locked to region 4, I ended up rarely using it because I had a lot of region 1 discs.
Anyway, I should have the image set up on a drive to test in the next day or so. That should establish whether we can go any further or not.
Posted Oct 20, 2007 · 15:27 UTC#9
Here goes nothing!
8)
Major difference in the radio part is that the European versions (HD1/HD3) have a different frequency grid, whilst the FM radio is also equiped with RDS and text, which also supply the TMC signal for the traffic info... in other words, the tuner is completely different and I would not be surprised if the Z2 software can't handle the radio part of the European unit...
Posted Oct 21, 2007 · 00:59 UTC#10
Here goes nothing!
8)
Major difference in the radio part is that the European versions (HD1/HD2) have a different frequency grid, whilst the FM radio is also equiped with RDS and text, which also supply the TMC signal for the traffic info... in other words, the tuner is completely different and I would not be surprised if the Z2 software can't handle the radio part of the European unit...
Yeah, that makes sense with the euro unit. However, the HD3 has none of that stuff here as our radio is basic as anything, lucky if a handful of the metropolitan stations have RDS solely for call sign purposes and that's it. The frequencies we have here are also a carbon copy of the US.
Posted Jan 29, 2008 · 08:38 UTC#11
Hey ozdude,
how did you go with your test. I'm also in Australia and was looking to do the exact same thing. Did you manage to load a HD3 image in a Z2?
Posted Jan 29, 2008 · 09:52 UTC#12
Hey ozdude,
Sorry for the lack of reply. Short answer is yes. It will work, but I need to finalise which files need replacing. I can boot the Aus image on the Z2 but I lose button labels for some strange reason. So I tried copying some directories from the US to the AUS image and found that's what needs to be done. This was before xmas, then I got busy. I'm on the verge of starting again and reckon I should have it done quickly as I can now set it up at home instead of taking time out my day at my friends shop to do it, which wasn't convenient.
Will have an update in the next few days. :D
Posted Jan 31, 2008 · 12:50 UTC#13
Curious how this works out.
hd3 has bluetooth built in, do you have the bluetooth for your z?
Posted Jan 31, 2008 · 23:52 UTC#14
Good news I finally got stuck back into 2 nights ago and it seems like I've succeeded. In the end I simply overwrote the HD3 map files folder on to the Z2 and bingo, Australian maps. I just have to take it down to my friends shop and make sure everything else is working as it seems to be. So in the end it seems all we need is about 1.5gig worth maps, unsurprisingly a far smaller amount of data than the U.S. maps hold!
I bought the bluetooth adapter online for the Z2 cheaply from the U.S. as well. The commonly available Pioneer unit available here is the same, just a bit more expensive(unsurprisingly).
Posted Aug 31, 2008 · 20:41 UTC#15
I have the same problem here! I live in Brazil and I bought a Z2 during my last trip to the US...
I have TeleAtlas Brazilian map that worked fine with Avic D3 - What are the odds of installing them into a Z2 unit and having them working properly?
Based on your thread OZDUDE it is perfectly possible, right? Could you give further details about your experience?
One question to you and/or those who had to opportunity to gain access to the original HDD: can you see all directories and files on your Windows file explorer when you connect the HD to your computer? Also base on your thread it seems so, but which is/are the map directories and file names on Z2?
There is a file explorer to Automobile Win CE that when used in D#, you just select the map file and execute it without any problem...
Anyone who could help on this?
Tks,
Posted Aug 31, 2008 · 23:40 UTC#16
Tks,
I'm still working on it and have been kind of busy. I found the I have to go and re-image the local software as my copy got corrupted when I upgraded the PC I had it on a couple of months ago. I finally got some time a couple of Saturdays ago only to work out that the local image I was working with was corrupted. So I now have to find time to go and get another copy off my friends AVIC HD-3.
You can see the files on the AVIC drive no problems, just make sure you've done all the standard unlocking explained here on the site.
Posted Oct 20, 2008 · 05:06 UTC#17
Well I would say I have now spent enough time trying various hybrids of the Z3 and HD3 software. Unfortunately the closest I seem to be able to get is that I have maps and all other functionality working, but the GPS never initializes. At this stage I have declared that I've spent enough time on the project. There is literally nothing left to try in the software. In the meantime I've also come to realise that the F900BT has a bunch of features much more suited to my needs, especially the iPhone compatibility, one thing which really failed to impress with the Z2/Z3. Also, some of the GPS data display features I lost from the factory nav I regain, which something I'm happy about.
So that the Z2 will be going in to a box and put up on eBay. I was nearly tempted into F900BT hacking on account of how straightforward it is but given the price point difference to me(special price form dealer friend) between the US retail and local -around $A500 landed(at current crap ex. rates), I am not as compelled to import one over buying it locally.
Sorry to all those that were waiting for a positive outcome, I wish I could have gotten that final bit to work. Time for me to move on.... 8)
Posted Apr 12, 2009 · 12:29 UTC#18
Are the Australian Avic HD3 units really identical to Avic Z2/Z3 units, only with a different label, while European Avic HD3´s have different radios?
Anyway, it seems noone have had any success in getting the navigation part of their Z3/HD3 units to work in other regions than where they "belong".
Posted Apr 13, 2009 · 01:46 UTC#19
It seems to me there is a firmware difference in there somewhere that will prevent the maps from functioning properly, other than that everything else works fine.
My thought is the easier unit to take across borders is the F900BT, since you can definitely load different GPS software into it because it is more like a real computer thanks to it's Win CE operating system. Moot point for me though now since I caved in and brought one locally. Still a lot of fun to hack though.
Posted Aug 29, 2009 · 01:12 UTC#20
What about putting X3 maps on Z3?
Could this work?
I want to do this to my HD3BT using X3 nav dvd's, since they are easy to obtain, and the nav software is much similiar!
Wich folders contain the maps?
