Nav problem
By YANKEES31 · Oct 18, 2007in Problems/Troubleshooting💬 8 posts👁️ 1,306 views
Posted Oct 18, 2007 · 13:31 UTC#1
I have had this unit for about a month now and every once and a while the Nav would loose track of where it was but would quickly right itself. Yesterday it started doing it alot and would take a long time to right itself. Is this an issue that will keep getting worse and lead to other issues. Any input would be appriciated.
Jared
Posted Oct 18, 2007 · 16:46 UTC#2
Did you hook up your VSS?
Posted Oct 18, 2007 · 22:47 UTC#3
I did not hook anything up, I had it installed but I do believe it is hooked up-I do get the MPH readout. why?
Posted Oct 18, 2007 · 23:01 UTC#4
There is more to it than that. I was in the same boat as you. I had mine professionally installed and I got the MPH readout.
Need to go to one of the pages...i believe it is called "sensors"
There should be a speed readout of some sort on there and it will read ZERO if it isn't hooked up.
Funny...when I called my guy, he came out and knew exactly how to hook it up. I am pretty certain that he was content blowing it off. The book says it just adds to your accuracy. I think it might help out the system when satellite coverage is sketchy.
It requires getting up under the hood.
Sorry my instructions weren't very detailed.
I'm not near my car
Good luck
Posted Oct 19, 2007 · 07:02 UTC#5
Go to your navi menu and choose Connection Status. Start driving and see if you get a beeping/reading under speed sense
Posted Oct 20, 2007 · 22:15 UTC#6
Nope the sensor is fine, it reads the MPH readout in that screen. Today it was even worse. Every day it seems to get worse and worse. This is very frustrating. I can only imagine what is going to happed to this thing when it gets hot out here.
Posted Oct 21, 2007 · 07:25 UTC#7
NOT the MPH, go to the connection status screen!!! Do you get a reading for VSS or not???
And all heat problems have been fixed via the update, so no reason to blame it on that
Posted Oct 23, 2007 · 21:42 UTC#8
did u fix it? I am in the same boat as you.
